Ability to see auto-generated pySourceStream for Sections
In older Pega version (6.x) I believe, if you open a section rule via Obj-Open, you would be able to review the generated pySourceStream stream where you can see the actual JSP-generated section code. In later versions, whether rule is checked in or not, the pySourceStream is always pzSectionBody_1(); except where rule is not auto-generated. I thought this would be generated on first use, however even packaged rules on higher environments show the same.
Is it possible to generate the actual jsp stream for a section rule?
As per my knowledge Pega has changed the logic for section in 7.x onwards and thus it doesn't keep the jsp within pySourceStream.
