ICA file creation failed. Cannot launch Citrix ICA client error
Our solution is trying to launch a published application from a Citrix server however, the Pega Robot Runtime is unable to launch the published application on our client machine due to error "ICA file creation failed. Cannot launch Citrix ICA client". When we are trying to launch the published application manually in the client machine, it is successfully launched.
We have verified that the Citrix context are correct since the same solution works on our Dev environment. The issue is only being encountered on the client machine in Production.
What should be done to fix this issue?
