How to monitor Delegated rule in production
Hi Team,
How to monitor Delegated rule in production. whether the user making changes to the delegated rule.
How to identify that?
Hi Team,
You can check in History tab> View full history
Apart from Rule History, Is there any OOTB option to know whether the user making to changes on the delegated rule.
Use activity HistoryOfHarnessRecord and pass pzInsKey to this activity.
You can turn on Checkout for the ruleset and enable Check-in approval for changes in order to monitor and control delegated rule changes.
You can also change Check in approval flow to auto-approve and notify someone/a group when changes are made, if the desire is to allow it but be told.
Hi
Cant we go for field level auditing in this case?
Regards
Bhavya
The rule history will tell you the timestamps and the user who updated it.
