How to disable an agent not to run on particular node?
Hi
Please go through Disable selected agents (blacklist) in the following link
You can use –DExcludeAgents
command to specify a list of agents that must not run on the node under any circumstance.
-DExcludeAgents=”RuleSet1:AgentName,RuleSet2:AgentName,…”
Thank You,
