ING
Last activity: 13 Jan 2017 6:44 EST
How can an operator select which workbasket to pull from
One department has one access group in Pega.
The access group has 2 workbaskets defined.
Now the operator pulls from 2 workbaskets without knowing which workbasket to pull from.
Part of the department works on 1 basket, part on the other basket. The entire department has only 1 LDAP group which gives them access to Pega via 1 access group.
I created 1 workgroup with one basket as a default and 1 workgroup with the other as default
The operator cannot select a basket in the caseworker screen.
What is the best way to deal with this: part of operators in 1 accessgroup may only work on basket 1 and other part of same group only works on basket 2.
Have you configured getNextWork in order to allow your enduser to pull items from workbasket ?
If yes then putting your logics there in getNextWork is a good option.
