How to access the querystring parameters outside of authentication activity?
As per our requirement we need to access the queryString parameters in one of our work level activity.
we tried to do this using pxHTTPServletRequest object. But we are not able to do it, as this object is available only when authentication activity run. for all other requests this object will not be available.
In authentication activity we can use below java code to access the querystring parameters.
String qString = ((javax.servlet.http.HttpServletRequest) tools.getRequestor().getRequestorPage().getObject("pxHTTPServletRequest")).getQueryString();
if (qString != null) {
String[] qsAry = qString.split("&");
for (int i = 0; i < qsAry.length; i++){
if (qsAry[i].indexOf("appName") >= 0) {
myStepPage.putString(".Application", qsAry[i].substring(qsAry[i].indexOf("=") + 1));
if (qsAry[i].indexOf("sysName") >= 0) {
myStepPage.putString(".System", qsAry[i].substring(qsAry[i].indexOf("=") + 1));
But as per our requirement we want to use similar code in Work level activity which will run once user login to the system. As pxHTTPServletRequest object will not be available once user login to system, we can't use this same code inside the work level activity.
Is there any way to achieve this requirement ?
