Syntel
Last activity: 5 Mar 2019 10:35 EST
How to pass parameters to Assignment from activity?
I am trying to pass some parameters from an activity to an assignment. In assignment I am choosing Worklist and then in router I am selecting ToWorkList. See attached snapshot for more details.
I assignment should route to user based on Param.AssignTo.
Areteans
Hi Chintan,
Instead of using Param.AssignTo. Create a Text Property with name AssignTo and set the value of that of property in Activity/DataTransform. So that it will be available in pyWorkPage and you can pass that to your assignment directly.
-Bala
Syntel
Thanks Bala, but this will require creating a property, I was wondering if there was a way by which we can directly pass the parameter directly to assignment.
Areteans Tech
Hi , did you try to store in any of the OOTB Property instead . (like pyTempText)
Syntel
Thanks Ashok, will try to use it!!
Areteans
Syntel
Thanks Kamalesh!!
PAF
You can try in various ways to get it done:
1) Create Data transform and map in flow connector
2) you can customize router activity and pass the param over there
3) Properties can be created and use it wherever require ( can be used for reporting as well in future to play around)
Karthick
Syntel
Thanks Karthick!!
Define the parameter in the activity and set it as OUT parameter, Also define the parameter in the flow and set it as IN parameter, the parameter gets passed from the activity to flow and you can use that parameter in the assignment routing.
Hope this helps
Syntel
Thank You!!
enGen Global Health Care
in activity we can set using property-set like pyLabel or pyTempText and use in assignment. No need of creating new property.
