Accenture
ES
Last activity: 5 Oct 2018 11:40 EDT
Authentication requirement on the Authentication Activity
In the "PortletAuthentication" activity. the SSO solution just work if I run at first time, if I logout and log on again doesn't load the information. the information is a PageList that inside there has a Data Page that load a Report Definiton.
but in the "pxRetriveReportData"(ootb) Activity is checked the "Required Authentication to Run" Checkbox.
the log show this Message when the Page List runs(just non-Working scenario):
"Only authenticated client may start this activity: RULE-OBJ-ACTIVITY RULE-OBJ-REPORT-DEFINITION PXRETRIEVEREPORTDATA..."
The Sso Works but don't retrive the data of the PageList, When this problem of "pxRetriveReportData" happens. In the Log file in the attachments show when retrive data and not retrive.
follow in attachments the Log file.
Note:
The property Pagelist load the workbaskets and set into the "workbasketlist" of the user(we use this because exist a especific logic to set each WorkBasket for each user. So we use this Report definition).
the question is:
Why at the first time this activity "pxRetriveReportData" runs?
And how can I solve this problem?
Thanks.
