AARETE
Last activity: 20 Aug 2018 16:40 EDT
Harness display fails for first time
I have an issue when I click on the option in nav menu. For the first time I keep getting error message that harness failed.
Hi Kishor,
Could you please attach the stack trace.
We might be able to figure out the cause of this issue from the logs.
Vikash
AARETE
Hi Vikash, See if this helps
From the logs seems that there is some cirumstance version of the section , check that try to give a unique namse and test it.
Secondly delete the temp folder from the server which will delete all the generated stream.
Please run tracer when you click on the option in nav menu and it will tell you where the error comes from.
The option in the nav menu usually has actions (activity, local action , etc.) associated with it. Somehow, the actions have issues.
Susan
AARETE
Hi Susan,
I have tried tracing this. I'm seeing this error
Failed to find a 'RULE-OBJ-MODEL' with the name 'SETDEFAULTCODEGROUPTYPE' that applies to '@baseclass'. There were 2 rules with this name in the rulebase, but none matched this request. The 2 rules named 'SETDEFAULTCODEGROUPTYPE' defined in the rulebase are: 2 related to applies-to class '@baseclass', but were defined on subclasses: 'PegaHealth-Work-CodeGroup'. |
Hi ,
Please check the pega rules log , it will give you the information that from where the process is getting failed.
J.P. Morgan Services India PVT Ltd
Hello, can you try it out with the administartor operator and check the behavior.
AARETE
Hello Neha,
Yes, I tired with administrator operator and I still have this issue.
Hello
Which version you are on?
Also, one idea could be to go to SMA and see how many instances of this rule are present in the cache by going to the rule cache management tab.
Delete all the cache and let it rebuild the cache again by launching it from navigation.
AARETE
Hello Santanu,
I have cleared the cache as well. No luck
Sai.
What Pega version are you using? Does it consistently fail on the first attempt?
The same type of error has been reported in 7.2.2 when the same user had multiple sessions.
AARETE
Hi Carissa,
We are using pega 7.2.1.Yes it fails constantly for the first time.
Tata Consultancy Services
HI,
Below link is similar to your post.
https://collaborate.pega.com/question/harness-fails-first-time
AARETE
Hi Gayatri,
The post you mentioned is different from this post.These are two different errors.
kishore
As this post is a duplicate of your newer post "Harness fails for the first time", I will close future comments on this thread. Please continue the discussion on your newer post.
Thank you!
