Flow without attached to a Case does not get Called in Mashup
Hi All - Can anyone help on the below
Requirement - Need to execute a flow not attached to a Case.
Scenario 1) :
I have a parent case : Org-AppName-Work-A-B for which case is created and a process attached to it . In the Mashup code this process is getting called which is expected behaviour
Scenario 2) :
Extended this parent class to have a child class , Org-AppName-Work-A-B-C for which there is No case in Case Management but have created a regular flow under this class In the Mashup code this flow is not getting called but calls the pyStartCase flow of the parent eventhough the names of both the flows do not match which is NOT expected behaviour . Need to create a temporary WO with no case ids generated . Have selected the create Temp Object also have selected Skip Create Harness
Tried the below 2 options in Mashup but still does not work
1)
data-pega-action ='createNewWork'
data-pega-action-param-classname ='Org-AppName-Work-A-B-C'
data-pega-action-param-flowname = 'flowNameforthisClass'
data-pega-action-param-harnessname = 'New'
data-pega-action-param-model ='Modelforthisclass'
2)
data-pega-action ='OpenWorkByURL'
data-pega-action-param-query ='pyActivity=Org-AppName-Work-A-B-C.OpenTestFlow'
Scenario 1) :
Scenario 2) :
1)
2)
Within the OpenTestFlow activty have a step to call the flow
Call NewFromFlow
params :
InsClass : Org-AppName-Work-A-B-C
FlowType : flowNameforthisClass
HarnessType : New
In both the above scenarios this flow is not getting called but calls the pyStartCase flow of the parent even though the names of both the flows do not match which is NOT expected behaviour
Danny
