Exercise System - Email Client doesn't load
http://env-39164146.pegaenablement.com:8100/ is the URL and the email client doesn't load. Unable to verify the work done because of that. Any pointers?
Hi @KManivel
The issue is most likely due to a security setting in your organization that blocks network traffic on port 8100.
You try to complete the exercise while you are outside the company network, for example from home.
Regards
Guru
