SANTANDER
Last activity: 19 Feb 2018 22:32 EST
Excluding certain assignments from GetNextWork (Customizing GetNextWork)
GetNextWork operates on a WB which has all pending approval assignments . But for a particular operator GetNextWork ( button ) should only return assignments worked by operators other than the current operator. (This is needed to prevent self approval of work . To give context , I am implementing buddy approval feature to CR case in Revision Manager Portal of Pega marketing which is nothing but normal case management under the hood)
Has anyone attempted this or a similar customisation to getNextWork ? Where should the customization go
Assign-.GetNextWorkCriteria (decision tree)
or in the following activities
- Work-.findAssignmentInWorkBasket
- Work-.findAssignmentInWorklist
- Work-.GetNextWorkObject
Your thoughts are appreciated in adavance.
Cheers & Regards,
MikeMiracle
