Exclude assignments where operator has no skill from GetNextWork
Hi all,
I have the following situation:
There is a workbasket which has assignments which require 1 of 3 different skills. When the user clicks "Get Next Work", an assignment should just be returned when the user has the required skill for this assignment.
Following example:
- Assignment 1 requires Skill A with Urgency 20
- Assignment 2 requires Skill B with Urgency 40
- Assignment 3 requires Skill A with Urgency 30
- Assignment 4 requires Skill C with Urgency 30
- User has Skill A
- Result = Assignment 3 will be opened for the user
To make it a bit more complex: As this requirement is just a pilot, business ask to only implement this logic if an assignment will be opened for a specific workbasket. Assignments from any other workbasket will only consider urgency and no skill.
How can I achieve this?
If you don't know for sure or can't answer everything, then also a hint in the right direction would be helpful.
Thanks and Best, Marcel
