Clone a Work Object
I need to create a clone of an existing WO through an Activity. In reading through some of the questions asked here, I was told that this could be solved by using 'Work-.CopyWork'. Can some one show with screenshots how I can create a cloned WO. For ex:- If my WO pzInskey ABC-DIV-UNIT Q-2378, how do I pass it, so that I may get a clone of the same in the following Activity?
@ChakriP8
By Opening and checking the utility CopyWork , I could understand from step 3 that the values are from Primary page.
So use it in the context of existing workitem [Step Page should have the values of old workitem]
Note : Step 1 -Check the Data transform pyCopyDefault (you can reuse this in your application layer to add the properties to be copied)
