Class Refactor - CS
Hi
I have a CS application which is already in production and has heavy integration. The application is implementation only. Work class has many subclasses which are cases.
We are coming up with a new business scenario which needs a class structure change as follow. Please let me know if someone has done this exercise and what challenges could arise using the class refactor wizard.
Existing classes :
Orgs-Dept-App-Work-Case1
Orgs-Dept-App-Work-Case2
Orgs-Dept-App-Work-Case3
New Class:
Orgs-Dept-App-Work-ABC-Case1
Orgs-Dept-App-Work-ABC-Case2
Orgs-Dept-App-Work-ABC-Case3
Hi RulesGuy,
Thanks for your time on posting your query in PSC!.
As per my knowledge class refactor is used for renaming the last name of the class structure, the wizard will also make reflect the references of old class names pointing to the new class names, but we can't modifty the class structure. You need to explicitly re-create the class structure based on your bussiness requirement.
For more help: Please go through our online help on class refactor.
https://community.pega.com/sites/default/files/help_v73/procomhelpmain.htm refactor
Best regards,
Naveen
