First Tech Federal Credit Union
ByPass Authentication checkbox in Standard agent processing doesn't work.
Hello Pega Team,
Even after 'Bypass activity authentication' checkbox selected in the standard agent, and the main activity modified with 'Requires Authentication' unchecked, subsequent activity calls are failing where 'Requires Authentication' is checked. Some of those activities are Pega OOTB final activities like Work-.pzLaunchInternalFlows
which has 'Requires Authentication' checked + couple of other activities in the concerned application which are in locked ruleset versions with 'Requires Authentication' checked. The development environment is Pega v7.2.2
The agent processing is failing because of this even after adhering to guidelines recommended by Pega. Please advise ASAP.
Best,
Rushikesh Patil
