Access group authentication doesn't seem to work correctly
I face the login popup after certain minutes by no processing is initiated. It seems that it is available to access a case despite cancel the login.
How should I configure to make authentication work correct? Should I also set requestor timeouts with the same value of authentication timeout?
- Pega Platform version: 8.2.x
I also have read the article below to try understanding about timeout mechanism.
https://community.pega.com/sites/default/files/help_v63sp1/Content/definitions/t/timeouts.htm
