Capgemini
Last activity: 19 Jun 2018 15:16 EDT
ExtractDataFromEForm With PDFEform doesn't work
I have a requirement on eForm. I uploaded a eForm template into pega through PDF for eForm wizard and same eForm send to customer through email. And customer fill the information and same as uploaded into Pega. Once upload is done, then filled information should be auto-fill in the respective screen.
Tried Solution- I able to get the full byte stream of the file content.After getting the stream content i am trying to map the stream content to pyEform property. But pyeForm is Java object data type and pyAttachstream is string type. I can't map the byte stream to Java Object.
How to parse the stream and how to extract the data by using ExtractDataFromEForm activity i don't have any clue.
Some one please help me, how to achieve the above mentioned requirement.
Veera.G
