BIX and Pega PRPC running on different nodes
Below is the architecture diagram we have for our application.
The description of the entire diagram is:
1) Firstly, we plan to copy production Pega database to a replicated database
2. Create a separate environment for BIX running on Pega 7.1.6
3. Pega agents on BIX server should capture cases from replicated database and extract to staging environment through BIX
Here is where my problem is. Can my BIX node communicate with the replicated Database to extract data from and load data into the Staging Database? If so, if I change the prconfig.xml for BIX to point to replicated Database, will my agents run? If not, is there an alternate approach to achieve this.
Venkat.
