SmartRules B.V.
Last activity: 9 Feb 2021 14:24 EST
Bix extract rule is not running on Background/bix node,only runs in webusernode. I am running extract rule using Jobscheduler.
I am trying to run Bix extract rule on schedule. To achieve that I am trying to run job scheduler on a specific node i.e. Background node or BIX. My Job scheduler is running fine on Webusernode.
I have added application in System Runtime Context as well. But when I am running it on Backgroundnode/Bix node I am getting below exception.
version we are using: Pega 8.4.2
Pega Bix:-08.04
com.pega.platform.executor.jobscheduler.scheduler.JobExecutionException: Activity execution failed with [PRRuntimeException]
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.execute(JobSchedulerProcessor.java:59)
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobRunTimeImpl.execute(JobRunTimeImpl.java:67)
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobRunTimeDecorator.execute(JobRunTimeDecorator.java:57)
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobExecutionTemplate.executeJob(JobExecutionTemplate.java:45)
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobExecutionTemplate.run(JobExecutionTemplate.java:35)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
Pega Bix:-08.04
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.pega.pegarules.pub.PRRuntimeException: PRRuntimeException
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:115)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1397)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1140)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1021)
at com.pega.pegarules.session.internal.PRSessionProviderImplForModules.doWithRequestorLocked(PRSessionProviderImplForModules.java:71)
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.execute(JobSchedulerProcessor.java:53)
... 12 more
Caused by: com.pega.platform.executor.jobscheduler.scheduler.JobExecutionException: Unable to execute the Activity
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.execute(ActivityProcessor.java:75)
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:113)
... 17 more
Caused by: com.pega.pegarules.pub.PRRuntimeException: Unable to process "Class of Extract rule mentioned here ABC-Work-XYZ"
at com.pega.pegarules.data.internal.access.ExtractImpl.parseAndRunExtractCommand(ExtractImpl.java:948)
at com.pega.pegarules.data.internal.access.ExtractImpl.executeCommandLineExtract(ExtractImpl.java:854)
at com.pega.pegarules.data.internal.PRDataProviderImpl.executeCommandLineExtract(PRDataProviderImpl.java:1698)
at com.pega.pegarules.session.internal.mgmt.Executable.executeCommandLineExtract(Executable.java:8789)
at com.pegarules.generated.activity.ra_action_pxextractdatawithargs_b390b959167377f95f63ce79c39386b3.step2_circum0(ra_action_pxextractdatawithargs_b390b959167377f95f63ce79c39386b3.java:316)
at com.pegarules.generated.activity.ra_action_pxextractdatawithargs_b390b959167377f95f63ce79c39386b3.perform(ra_action_pxextractdatawithargs_b390b959167377f95f63ce79c39386b3.java:93)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2814)
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.runActivity(ActivityExecutor.java:47)
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.executeActivity(ActivityExecutor.java:38)
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.execute(ActivityProcessor.java:60)
I have passed required parameters as well to pxExtractDataWithArgs activity as well.
The things I already tried.
- selected all the possible combinations of Associated with node types and Runs on drop down from the job scheduler rule. It only works when i select webuser node. But we need it should run on Background node.
- Added the option of "include in the background processing" check box in application definition under advance tab.
- Restarted the background nodes yesterday.
- Tried to change the application names in SRC
- unfortunately, unable to get the exact error as the logs are getting logged on another node. but able to capture errors from admin studio. which are pasted above in the email.
- Able to see same SRC on admin studio which has my application listed in SRC.
- Added required access role as well for the particular class in the Access group to make sure its not a access issue.
@YogeshW4666 : Hello friends I am able to resolve the issue. The problem was the folder where we need to copy the extract using job scheduler was not available on the background node. I created the desired folder structure and now the job scheduler is also working on Bix/Background node as well. thanks all.
