Capgemini
Last activity: 26 Feb 2019 2:48 EST
Application wizard showing blank screen
Browse option is not showing in application wizard.
Error from log files :
Failed to generate com.pegarules.generated.html_section.ra_stream_pxbrowselocalfiles_e8c5e933461cb49332f86fc977dc37a5
com.pega.pegarules.pub.generator.FirstUseAssemblerException: Failed to compile generated Java com.pegarules.generated.html_section.ra_stream_pxbrowselocalfiles_e8c5e933461cb49332f86fc977dc37a5: ----------
1. ERROR in /com/pegarules/generated/html_section/ra_stream_pxbrowselocalfiles_e8c5e933461cb49332f86fc977dc37a5.java (at line 245)
tools.appendString("' " + pega.getUIEngine().getFVInspectorUtils().startCollectingFieldValueData() + pzCell.getInspectorDataDynamic("Label",null,".pySections(2).pySectionBody(1).pyTable.pyRows(1).pyCells(1)") + " class='content-item content-label item-" + Integer.toString(index) + " " + pzSection.getCustomStyle(false, "","helper_text_dataLabelRead","helper_text_dataLabelWrite") + " ' STRING_TYPE='label' RESERVE_SPACE='false'><div class='content-inner '>" + "<div " + pzCell.getTestIdIfEnabled("2015010604170007313441") + " class='field-item " + pzSection.getCell().getLabelErrorSkin("To import an already uploaded file, click "Next" below to select a file","") + pzSection.getCustomStyle(false, "","dataLabelRead helper_text_dataLabelRead","dataLabelWrite helper_text_dataLabelWrite") + "' >");
Syntax error on token "Next", invalid AssignmentOperator
1 problem (1 error)
Compile failed.
From: (H2A9580588F2966E4A67B58C49DCF2A88: Proprietary information hidden)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.writeJavaFileAndCompileAndLoad(AssemblyCacheBase.java:1610)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.buildAndOrLoadJavaClass(AssemblyCacheBase.java:1692)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.getGeneratedJava(AssemblyCacheBase.java:3100)
at com.pega.pegarules.generation.internal.cache.appcentric.RACacheAppCentricImpl.addEntryToMemoryCache(RACacheAppCentricImpl.java:1159)
at com.pega.pegarules.generation.internal.cache.appcentric.RACacheAppCentricImpl.find(RACacheAppCentricImpl.java:1007)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheWrapper.find(AssemblyCacheWrapper.java:795)
at com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.getInternal(FUAManagerImpl.java:1415)
at com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.get(FUAManagerImpl.java:1304)
at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:500)
at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:716)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.getStream(IncludeStreamRuntime.java:332)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.emitIncludeStreamReference(IncludeStreamRuntime.java:252)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.emitIncludeStreamReference(AutoStreamRuntimeImpl.java:363)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.sectionBodyIncludeInCell_1(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:315)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.simpleLayoutCell_1(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:345)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.simpleLayout_1(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:390)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.pzLayoutBodyWrapper_1(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:230)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.pzLayout_1(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:410)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.pzSectionBody_1(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:219)
at com.pegarules.generated.html_section.ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.execute(ra_stream_pxbrowselocalfileswrapper_5253fbf52c846f70864aae4fdf1139ff.java:100)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:4060)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuleRuntime.getSectionStream(AutoStreamRuleRuntime.java:149)
at com.pegarules.generated.flowaction.ra_stream_pxselectlocalfile_c89f4d68a397cc2c3d59139ab85ca17c.includeSectionBody_1(ra_stream_pxselectlocalfile_c89f4d68a397cc2c3d59139ab85ca17c.java:239)
at com.pegarules.generated.flowaction.ra_stream_pxselectlocalfile_c89f4d68a397cc2c3d59139ab85ca17c.execute(ra_stream_pxselectlocalfile_c89f4d68a397cc2c3d59139ab85ca17c.java:134)
at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:733)
at com.pegarules.generated.html.ra_stream_flowactionhtml_51c667f4374c6451e9b613c576c73f15.execute(ra_stream_flowactionhtml_51c667f4374c6451e9b613c576c73f15.java:392)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3888)
at com.pegarules.generated.html_section.ra_stream_flowactionhtml_simple_75110f1f216ecc8580ad274a9b38e46e.execute(ra_stream_flowactionhtml_simple_75110f1f216ecc8580ad274a9b38e46e.java:248)
at com.pegarules.generated.html_section.ra_stream_wizardscreenflowshellnosteps_05ad41797cc7eeacaf16a7570f888c15.execute(ra_stream_wizardscreenflowshellnosteps_05ad41797cc7eeacaf16a7570f888c15.java:116)
at com.pegarules.generated.html_harness.ra_stream_wizardscreenflownosteps_55526676ccd5b6b5d0fd59d4c1c455a5.includeSectionBody_3(ra_stream_wizardscreenflownosteps_55526676ccd5b6b5d0fd59d4c1c455a5.java:2840)
at com.pegarules.generated.html_harness.ra_stream_wizardscreenflownosteps_55526676ccd5b6b5d0fd59d4c1c455a5.generatePegaHarnessDiv_1(ra_stream_wizardscreenflownosteps_55526676ccd5b6b5d0fd59d4c1c455a5.java:2497)
at com.pegarules.generated.html_harness.ra_stream_wizardscreenflownosteps_55526676ccd5b6b5d0fd59d4c1c455a5.execute(ra_stream_wizardscreenflownosteps_55526676ccd5b6b5d0fd59d4c1c455a5.java:709)
at com.pegarules.generated.activity.ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.step6_circum0(ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.java:684)
at com.pegarules.generated.activity.ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.perform(ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.java:155)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3527)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10674)
at com.pegarules.generated.activity.ra_action_displayharness_1d414472711606645476be6f8133a69a.step2_circum0(ra_action_displayharness_1d414472711606645476be6f8133a69a.java:336)
at com.pegarules.generated.activity.ra_action_displayharness_1d414472711606645476be6f8133a69a.perform(ra_action_displayharness_1d414472711606645476be6f8133a69a.java:86)
at com.pegarules.generated.activity.ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.step16_circum0(ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.java:1211)
at com.pegarules.generated.activity.ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.perform(ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.java:352)
at com.pegarules.generated.activity.ra_action_add_4f8377b6e4507143676c05b5ce0b7b96.step10_circum0(ra_action_add_4f8377b6e4507143676c05b5ce0b7b96.java:1029)
at com.pegarules.generated.activity.ra_action_add_4f8377b6e4507143676c05b5ce0b7b96.perform(ra_action_add_4f8377b6e4507143676c05b5ce0b7b96.java:229)
at com.pegarules.generated.activity.ra_action_new_b411432bd3c2f0b0ce0fc0c588fdeed2.step12_circum0(ra_action_new_b411432bd3c2f0b0ce0fc0c588fdeed2.java:952)
at com.pegarules.generated.activity.ra_action_new_b411432bd3c2f0b0ce0fc0c588fdeed2.perform(ra_action_new_b411432bd3c2f0b0ce0fc0c588fdeed2.java:282)
at com.pegarules.generated.activity.ra_action_startwizard_ece57cc11a312ca0ebeacfc31fb56353.step13_circum0(ra_action_startwizard_ece57cc11a312ca0ebeacfc31fb56353.java:1079)
at com.pegarules.generated.activity.ra_action_startwizard_ece57cc11a312ca0ebeacfc31fb56353.perform(ra_action_startwizard_ece57cc11a312ca0ebeacfc31fb56353.java:294)
at com.pegarules.generated.activity.ra_action_douiaction_98816bb549c28acd89176d91f202697a.step27_circum0(ra_action_douiaction_98816bb549c28acd89176d91f202697a.java:2858)
at com.pegarules.generated.activity.ra_action_douiaction_98816bb549c28acd89176d91f202697a.perform(ra_action_douiaction_98816bb549c28acd89176d91f202697a.java:509)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:467)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3166)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390)
at sun.reflect.GeneratedMethodAccessor87.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1301)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1038)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:893)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:825)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:327)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:270)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor68.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:246)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:594)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:390)
at sun.reflect.GeneratedMethodAccessor86.invoke(Unknown Source)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:575)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1233)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:782)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:481)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1114)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:949)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88)
at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCallback.complete(SSLReadServiceContext.java:1833)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892)
