Chevron
Last activity: 21 Aug 2018 16:48 EDT
Why is my autocomplete showing blank results?
My autocomplete is showing blank results. I have already tried using report definition and data page.
There is only 36 records.
Chevron
This has been resolved, I had an error in the data source property
Can you please check it is really blank? It might be possible that results are present, but due to the font color, you are not able to see in the front end. Please use developers tools to verify if they are really missing.
Chevron
Yes, it is blank. At no point did I change the font color, and the results show when I use anything else such as a drop down list. This is only happening with autocomplete.
Jill Hartley Sai Mouneendra Reddy Chinthala Preksha Sharma Rajesh Yekkala
If you run report definition and data page directly, do you get records? If yes, then somewhere your auto complete configuration has some problem.
Please refer to OOTB section @baseclass "pxUIGalleryAutoCompleteWrapper". In the last Dynamic Layout, there are examples for "Report Definition" and "Data Page".
Chevron
Yes, I followed this correctly I believe. I noticed that it will work if I use a data page containing a lower amount of records. When I switch it to report definition is when I get blank values even with a low amount of records. Do I need to manually create a report definition. So far I am just using the one that is automatically created "DataTableEditorReport"
Tata Consultancy Services
Could you please provide snapshots of your autocomplete configuration.
Updated: 21 Aug 2018 12:29 EDT
Chevron
Is this what you're looking for?
Chevron
lu nan Shrikant Tale
Thanks for updating your post wiht your resolution @JoshuaL7379! I've marked your reply as the Correct Answer!
