IBM India Pvt Ltd
Last activity: 16 May 2017 15:05 EDT
accessing external systems excercise
In the exercise related to the topic - accessing external systems we need to upload a .Jar file from the instructions for installing updates link. I followed the procedure for importing the file through the import wizard and completed the process. However, I do not see the imported properties, rules, data pages from the .jar file in the data class. While SAE-HRservices-Backgroundcheck etc are visible through the search bar, I do not see the associated rules and properties. I tried to re import the .Jar file and the system throws the following error. How do I delete the data so that the system allows me to re import the files? or is there any other solution for the properties and data to be visible.
Check your class structure naming conventions. Most likely the application you built has a different class structure. You can try the renaming wizard to fix this.
Bill Rathert
