Pega Infinity Patch Calendar
Pega Platform patch release calendar
The calendar below provides an overview of the anticipated release dates for upcoming Pega Platform patches. Note these dates are subject to change.
Pega Infinity '26 and '25
Standard Support |
Pega Infinity '26release 26.1.0 GA: July 14, 2026 |
Current Patch 26.1.1 |
26.1.2 Dec 2026 |
26.1.3 Mar 2027 |
26.1.4 Jun 2027 |
26.1.5 Sep 2027 |
26.1.6 |
Standard Support |
Pega Infinity '25release 25.1.0 GA: Sep 24, 2025 |
25.1.1 |
25.1.2 |
25.1.3 |
Current Patch 25.1.4 |
25.1.5 Jan 2027 |
25.1.6 Apr 2027 |
Pega Infinity 24.2 and 24.1
Note The following releases have moved into extended support and no longer receive patches.
Extended Support |
Pega Infinity '24.2release 24.2.0 GA: Oct 29, 2024 |
24.2.1 |
24.2.2 |
24.2.3 |
24.2.4 |
Final Patch 24.2.5 |
| Extended Support | Pega Infinity '24.1release 24.1.0 GA: Apr 16, 2024 |
24.1.1 |
24.1.2 |
24.1.3 |
Final Patch 24.1.4 |
Security Patch 24.1.5 |
Pega Platform 23.1 and older
Note Support has ended for these releases.
| Exited Support | Pega Infinity '23.1release 23.1.0 GA: Sep 13, 2023 |
23.1.1 |
23.1.2 |
23.1.3 |
23.1.4 |
Final Patch 23.1.5 |
| Exited Support | Pega Platform 8.8GA: Oct 18, 2022 |
8.8.1 |
8.8.2 |
8.8.3 |
8.8.4 |
Final Patch 8.8.5 |
| Exited Support | Pega Platform 8.7GA: Jan 27, 2022 |
8.7.1 Mar 25, 2022 | 8.7.2 Jun 17, 2022 | 8.7.3 Aug 1, 2022 | 8.7.4 Nov 11, 2022 | 8.7.5 Apr 5, 2023 | Final Patch 8.7.6 Sep 29, 2023 | |||
| Exited Support | Pega Platform 8.6GA: May 17, 2021 |
8.6.1 Aug 5, 2021 | 8.6.2 Sep 30, 2021 | 8.6.3 Feb 8, 2022 | 8.6.4 May 4, 2022 | 8.6.5 Jul 7, 2022 | Final Patch 8.6.6 Dec 1, 2022 | |||
| Exited Support | Pega Platform 8.5GA: Aug 31, 2020 |
8.5.1 Oct 6, 2020 | 8.5.2 Dec 9, 2020 | 8.5.3 Mar 19, 2021 | 8.5.4 Jun 24, 2021 | 8.5.5 Aug 31, 2021 | Final Patch 8.5.6 Apr 7, 2022 | |||
| Exited Support | Pega Platform 8.4GA: Feb 26, 2020 |
8.4.1 Apr 13, 2020 | 8.4.2 Jul 31, 2020 | 8.4.3 Oct 14, 2020 | 8.4.4 Jan 28, 2021 | 8.4.5 Jul 14, 2021 | Final Patch 8.4.6 Nov 1, 2021 | |||
| Exited Support | Pega Platform 8.3GA: Aug 13, 2019 |
8.3.1 Oct 18, 2019 | 8.3.2 Feb 28, 2020 | 8.3.3 Apr 30, 2020 | 8.3.4 Aug 28, 2020 | 8.3.5 Nov 23, 2020 | Final Patch 8.3.6 May 28, 2021 | |||
| Exited Support | Pega Platform 8.2GA: Feb 28, 2019 |
8.2.1 Mar 26, 2019 | 8.2.2 May 30, 2019 | 8.2.3 Aug 9, 2019 | 8.2.4 Sep 19, 2019 | 8.2.5 Nov 7, 2019 | 8.2.6 Mar 9, 2020 | 8.2.7 Jun 18, 2020 | Final Patch 8.2.8 Nov 5, 2020 | |
| Exited Support | Pega Platform 8.1GA: Oct 1, 2018 |
8.1.1 Nov 1, 2018 | 8.1.2 Dec 6, 2018 | 8.1.3 Feb 4, 2019 | 8.1.4 Mar 26, 2019 | 8.1.5 Apr 24, 2019 | 8.1.6 Jul 31, 2019 | 8.1.7 Oct 24, 2019 | 8.1.8 Apr 1, 2020 | Final Patch 8.1.9 Oct 27, 2020 |
For more information please refer to the article regarding Pega's Extended Support Program.
For a list of currently available patches, see the following articles:
Pega Customer Decision Hub patch release calendar
The following calendar provides an overview of the past and anticipated release dates for upcoming Pega Customer Decision Hub™ patches. Note that these dates are subject to change.
There is a 1:1 dependency between the Pega Platform patch release version and the Pega Customer Decision Hub patch release version (both need to be on the same patch release number).
Standard Support |
Pega Customer Decision Hub '26release 26.1.0 GA: July 14, 2026 |
26.1.2 Dec 2026 |
26.1.3 Mar 2027 |
26.1.4 June 2027 |
26.1.5 Sept 2027 |
26.1.6 |
Standard Support |
Pega Customer Decision Hub '25release 25.1.0 GA: Sep 24, 2025 |
25.1.1 |
25.1.2 |
25.1.3 |
25.1.5 Jan 2027 |
25.1.6 Apr 2027 |
Pega supports patches for Pega Customer Decision Hub starting with release 25.
For Pega Customer Decision Hub releases 24.2 and earlier, patches are not available. Pega continues to support these releases with hotfixes. For more information, see Required hotfixes for Pega Customer Decision Hub and Pega 1:1 Operations Manager.
Pega Customer Service, Pega Sales Automation, Pega Call, Pega Knowledge, Knowledge Buddy and Common Data Model
The calendar below provides an overview of the anticipated release dates for upcoming Pega Customer Service, Pega Sales Automation, Pega Call, Pega Knowledge and Common Data Model patches. Unless noted otherwise, there is a 1:1 dependency between the platform patch release version and the application release version (both need to be on the same patch release number). In the case of exceptions when applicable, see below.
* Only the applications listed here are in Patch mode, all the remaining applications including industry-specific variants of the listed apps will continue to follow the Hotfix process
- Pega Customer Service, Pega Call, Pega Knowledge provides a patch release version matching every platform patch release version number.
- 24.1.5 is a platform-only security patch, and there is no corresponding application patch release. 24.1.4 remains the final application patch release.
- Sales Automation provides a patch release for the x.x.1 of a minor release only, for example, the platform 23.1.1 release will be matched with a 23.1.1 for Sales Automation, but it only ever produces a single patch release on a minor series. So if you are on platform 23.1.2 for example, your matching Sales Automation patch release will always be 23.1.1.
- Common Data Model provides patch releases but not for every incremental patch. Look for 'CDM' references for patch releases in the table below for releases where CDM has a patch release.
- Knowledge Buddy provides patch releases, but not for every incremental patch. Look for 'KB' references for patch releases in the table below for releases where KB has a patch release.
Standard Support |
26.1.0GA: July 14, 2026 |
Current Patch 26.1.1 Sep 1, 2026 |
26.1.2 Dec 2026 |
26.1.3 Mar 2027 |
26.1.4 Jun 2027 |
26.1.5 Sep 2027 |
26.1.6 | |||||
Standard Support |
25.1.0GA: Sep 24, 2025 |
25.1.1 Nov 6, 2025 |
25.1.2 Feb 17, 2026 |
25.1.3 Jun 5, 2026 |
Current Patch 25.1.4 Oct 1, 2026 |
25.1.5 Jan 2027 |
25.1.6 Apr 2027 |
Extended Support |
24.2.0GA: Oct 29, 2024 |
24.2.1 Mar 10, 2025 |
24.2.2 May 21, 2025 |
24.2.3 Nov 21, 2025 |
24.2.4 Mar 24, 2026 |
Final Patch 24.2.5 June 25, 2026 |
Extended Support |
24.1.0GA: Apr 16, 2024 |
24.1.1 Jul 23, 2024 |
24.1.2 Dec 9, 2024 |
24.1.3 Apr 14, 2025 |
Final Patch 24.1.4 Jan 9, 2026 |
Extended Support |
23.1.0GA: Sep 13, 2023 |
23.1.1 Jan 5, 2024 |
23.1.2 May 3, 2024 |
23.1.3 Aug 28, 2024 |
23.1.4 Jan 8, 2025 |
Final Patch 23.1.5 Sep 22, 2025 |
Link Legend:
CS + Call: Pega Customer Service and Pega Call release notes, KM: Pega Knowledge Management release notes, CDM: Common Data Model release notes, SA: Pega Sales Automation release notes, KB: Pega GenAI Knowledge Buddy release notes
