There are no client-reported issues resolved in the 24.1.5 patch. As part of Pega's long-term security strategy, AI-assisted scanning has been implemented on a proactive basis. Pega strongly encourages all clients to stay current on the latest product versions, where security enhancements, patching, and hardening improvements are delivered. This patch contains several security updates which are recommended for all clients on Infinity '24.1.
Fixed issues with update impact
Symptoms and Impact
In Pega Platform '24.1.5, the rules update can fail during the Context Update step. Logs show that pzQueueProcessRuleForGuardrails fails to trigger due to insufficient authentication.
All direct upgrades to Pega Platform '24.1.5 from Pega Platform version 7.1.10 or earlier will fail on this step. There is a small risk of failure when updating from other source versions earlier than 24.1.0.
The issue is only present when updating to 24.1.5 and is not present when updating to 24.2 or higher.
Solution
Update to a later release such as Pega Platform '26.1.
If an update to the latest Pega Platform '25.1 or '26.1 is not possible, you can perform a direct update to 24.1.4 first and following that you can carry out a patch update to 24.1.5.
