Issue
User is unable to integrate with agile workbench. Hence, the operators are unable to work on the agile cases and user stories.
Error
Enter a valid Agile Studio URL
Steps to reproduce
To integrate agile workbench with agile studio, refer to the article below,
Integrating Agile Workbench with Pega Agile Studio
Root Cause
The error is caused by incomplete OAuth 2.0 Client Registration configuration. The out-of-the-box AgileWorkbench OAuth 2.0 Client Registration references the AgileStudioSysArchitect operator by default. If this operator is disabled or not properly configured, the integration fails with the URL validation error, even when the URL format is correct.
Solution
The issue is resolved by properly configuring the OAuth 2.0 authentication profile with the correct parameters, updating the application settings to reference this authentication profile, and enabling the AgileStudioSysArchitect operator as required.
Note - If the operator, AgileStudioSysArchitect, is present in the OAuth 2.0 Client Registration, then follow this article.
If the operator, AgileStudioSysArchitect, is not used, then replace the AgileStudioSysArchitect operator reference with your actual operator ID.
