Issue
After upgrading to Pega Infinity™ 25.1.2 from an earlier Pega Infinity release, applications using When conditions within embedded modal windows experience unexpected behavior.
Symptoms and Impact
Visibility conditions defined on embedded data or modal views are no longer evaluated correctly, resulting in UI elements not rendering. This primarily affects visibility logic defined on View rules, causing fields or UI sections to remain hidden even when conditions should evaluate to true.
The issue is most prevalent when server‑side When rules are used to control visibility in embedded contexts, however the same behavior can be seen in Views using When rules affecting Disabled /Edit conditions.
Steps to reproduce
Create a View and add two properties: Property1 (Select Party) and Property2 (Party relationships). Property1 has a dropdown control with a list of possible values.
Configure Property2 with Visible When rule to show only if a value of Property1 is selected.
Select a value from Property1 dropdown. This should show Property2 but the Property does not display.
Root Cause
This behavior is a regression and impacts existing client configurations that were previously working prior to the upgrade.
The issue has been identified as a side effect of changes made in Pega Platform 25.1.2 regarding data restoration logic for case reopening operations. As a result, When conditions evaluated in embedded modal views do not receive the required context, and the view is not updated correctly.
Solution
The issue has been fixed in the following releases:
- Pega Infinity '26.1
- Pega Infinity '25.1.3
Local change for Pega Platform 25.1.2:
To avoid the Issue, use a Client‑side custom conditions to control visibility, as these are evaluated on the client and are not impacted by the server‑side context merge issue.
This workaround will need to be reverted when an update implements the permanent fix because:
Clients may already have working configuration based on When rules.
Refactoring existing logic may not be feasible or acceptable in the short term.
Hotfix for Pega Platform 25.1.2
The following hotfix exists to mitigate the problem:
HFIX-D707
Constellation Hotfixes are provided via a URL which can be implemented by setting the DSS ConstellationPegaStaticURL to this value, and reverted by setting the previous value if needed.
Hotfix URL for DSS: https://release.constellation.pega.com/25.1.2-HFIX-20260327130724
Hotfix for Pega Customer Service 25.1.2
Hotfix URL for CS DSS: https://release.constellation.pega.com/cs/25.1.2-HFIX-20260330070733
This issue has been addressed in the latest releases where there is an improved handling around updating context_data when merging interest-path data so context metadata stays in sync with the primary data merge.
