Capgemini Technology Services
Last activity: 5 Jun 2025 10:13 EDT
How to Display Checkboxes Beside Each Option in a Multi-Select List Dropdown (Data Page Source)?
I'm using a multi-select list control sourced from a data page (D_CountryList
) that returns a list of key-label pairs based on a parameter. I want to display a checkbox next to each option in the dropdown so that users can clearly see which items are selected — similar to how you would display a list with explicit [ ] Option 1
, [✓] Option 2
, etc.
Is it possible to render actual checkboxes in each row of the multi-select dropdown using the multi-select list control?
If not, what is the recommended approach in Pega to display a list of selectable options with visible checkboxes, especially when using a data page as the source?
Appreciate any suggestions or best practices for implementing this use case.
