TTEC
Last activity: 30 Jan 2025 10:56 EST
Cisco Finesse v15 Support
Please share the timeline for when Pega will support integration with Cisco Finesse v15.
Reply
Updated: 30 Jan 2025 10:56 EST
@AlisonB90 (cc @Keith_W6 ) yes, we support Pega Call OOTB Finesse connector with Cisco Finesse 12.6.2 ES4, I don't see the Finesse version 15 to download from Cisco site, can you please clarify !!
Updated: 17 Jan 2025 9:25 EST
@AlisonB90 did you carry out a PSC key word search?
Did you check the documentation? In which document are you looking for version-specific support?
I found the following carrying out a Cisco Finesse search:
Considerations for Cisco CTI links
Pega CTI cisco finesse integration through API
@SandeepPenumadu the user needs assurance that 'Cisco Finesse version 11.5 or higher' includes Cisco Finesse version 15. Please can you confirm this is supported?
TTEC
@MarijeSchillern I don't see anything in the documentation you shared about when Pega integration will support CISCO Finesse V15.
Correct me if I'm wrong, but in the table that @MarijeSchillern shared above in her reply, it appears that our requirements to use Cisco Finesse are versions 11.5 and higher.
HCA Healthcare
Currently, Pega has not officially announced support for Cisco Finesse version 15. Based on the latest information, Pega Call supports Cisco Finesse versions starting from 11.5 and higher. If you are looking for integration with Cisco Finesse v15, I recommend reaching out to Pega's support team or your Pega account manager for detailed information. They can confirm whether integration is planned and provide timelines for support. This ensures you have accurate and up-to-date details to plan your implementation effectively
Updated: 17 Jan 2025 9:23 EST
TTEC
@Sairohith This really doesn't answer the question. Sounds like Pega doesn't officially support integration with Cisco Finesse v15.
@AlisonB90 I do not see any mention of Finesse v15 any where on the cisco site. Cisco Finesse 12.6.2 ES4 is the latest release available and is supported by Pegacall 24.1. As newer versions come out they will get tested our the latest Pega GA release available at that time.
Cisco docs show the latest releases available are:
- Finesse 12.6(2)ES4
- latest available download.
- UCCE 12.6(2)
- UCCX 12.5(1)
- CUCM 15(su2)
Are you by chance referring to CUCM?
