adding attachment in data class section in UI Pages without creating Work Object
I have a requirement, where on UI Pages , have to show section from a data type containing columns such as category, description etc. On section I have Provided Add Action which can add new row to datatype(done using savable datapage).Now requirement is user should be able to add attachments as well.
How we can add attachments in Data instance only without WorkObject??Also how to upload files in UI Pages.
@MarijeSchillern thanks for reply. To resolve above challenge, We used pyUploadFileWithBrowseOption as local action which is in Data- Class.However, another issue I encountered was ,In Clipboard I could see file Name in pyFileNameHolder , but we cannot use this property as it was saying invalid property .It seems this property exist in Data-NLP class instead of baseclass. Hence, there was no way to use this property.
Pegasystems, suggested one workaround "The fix was a local change to save the OOTB UploadFile activity to a custom ruleset and change the property name from 'pyFileNameHolder' to a custom property name created in Data- class. After making this change the uploaded file name is being set for the custom property and it is available for the activity to retrieve the uploaded file name."
I implemented this along with saving as the flow action pyUploadFileWithBrowseOption and section UploadFileWithBrowseOption. Now the attachments are working in the Data instance only.
@Pegasystems Should give a permanent fix for this and make the pyFileNameHolder in baseclass for use. This issue was 4 years back with SR-D46394, in one of the articles I found it https://support.pega.com/question/file-name-uploaded-file,but still no fix is there in latest versions.
