Tcs
Tcs
Tcs
Posted: Jul 22, 2024
Last activity: Aug 7, 2024
Last activity: 7 Aug 2024 5:25 EDT
Constellation , UI Data update issue
I took the data from the data object into the conestellation UI through the views(savable data page), view has edit, add and delete options, but i could not able to create new entry or modify the data from the UI.
i tried to see the logs through the network logs, api was failing with the error createworkobject api.
Pls help us here.
Srinivasula Reddy
9441556666
***Edited by Moderator Rupashree S. to change Content Type from Discussion to Question; added capability tags***
