PEGA UI Pages availability to application built on UI-Kit
My application is currently using UI-Kit. Is it required to migrate to Theme Cosmos to use the UI Pages ? Will I be able to make any configuration changes to make the app studio support with UI Page and Navigation option without changing to theme Cosmos.
@AnandR
Attaching the PDF which contains details to migrate the Application from UI kit to Theme Cosmos. If you are not able to access above document.
Follow these steps
The level of effort to migrate to Cosmos depends on several factors.
Un-overriding rules you should no longer override.
Refactor sections to use design templates
Customize the Summary Panel
Customize the vertical tabs on a case.
Brand your application through App Studio
@AnandR
Follow these steps
Also, please refer the below mentioned links for further details:
https://docs.pega.com/bundle/platform/page/platform/user-experience/theme-cosmos-ui-kit.html
https://design.pega.com/design/getting-started/
