Verizon Data services India
Last activity: 6 Jun 2024 11:42 EDT
TurnOffSecurityForExportToExcel DSS is not found in Pega 8.6?
We are trying to export the excel file which contains one of the column as some excel function. But on export excel is adding single quote (') in front of the value which interns excel considering that value as a normal text. But it is actually a excel forumal.
Found that there is a DSS introudced with name TurnOffSecurityForExportToExcel to off the security so that pega will not add that single quote before the value while exporting. This DSS is in 8.4.1, but not able to find it in 8.6.1.
please provide some inputs on this dss TurnOffSecurityForExportToExcel, is it removed in later versions or modified to some other name or any other approach to avoid that single quote infront of the value on export?
***Edited by Moderator Marije to add Case INC-B6337 tags***
