Password Analyzer tool
Is there a tool to look at default operator ids and check their passwords to see if they are changed?
***Edited by Moderator Rupashree to add Capability tags***
Hi @DPCLARK12: Can you please check this.
I don't see a option to list the operators. Instead you can use this utility to disable default operators.
Thanks.
Hi @DPCLARK12
You can check their current password in the query runner, but it is encrypted.
select data.pr_read_from_stream('pyPwdCurrent' , pzInsKey, pzPVStream) AS Password from data.pr_operators where pyUserIdentifier='[email protected]'
Still if you want last Sign On You can Open respective operator Access Group, and then check in the Operator Tab--> Last Sign On
Ashok
Support Doc
