Ford Motor Company Ltd
Posted: Jan 18, 2024
Last activity: Feb 5, 2024
Last activity: 5 Feb 2024 10:04 EST
STOP failed for Robot (HostName). The command message was not delivered to the robot.
- Enabled Auto-Balancing(AB) for two WGs and only single bot is available. Evalutation time is 60 mins.
- Please refer attachements for audit.
- It worked fine under first work group(operations) which is having an assignment of SLA of 3hrs. Once the 5hrs SLA of an assignment in another WG(TestV22) falls under the evaluation time, AB tried to stop the bot.
- Later observed a exception in audit from RM. Please let me know all the possible scenarios where RM might throw this particular exception. What changes we need to do in order to resolve it? Why the stop command is not getting delivered to bot?
- And when I tried to stop the bot manually it does not shows the optional at all. Only Terminate is available. In this way manual intervention is needed to terminate and run it. Please let me know why this happens and how to avoid it?
- Please let me know if you need any other details.
- Thanks.
***Edited by Moderator Rupashree to add Capability tags***
