Cotiviti
Last activity: 14 Oct 2021 16:02 EDT
Error In New Application Creation
I am getting error while creating new application.
You are not authorized to create, modify, or lock instance DATA-ADMIN-DB-TABLE HISTORY-MYWorkClass
Logs:-
Logs:-
Problem executing SQL to update database schema : CREATE TABLE cpe_bprms.pc_History_MyWorTable ( "PXADDEDBYID" VARCHAR2 (128 CHAR), "PXADDEDBYSYSTEM" VARCHAR2 (64 CHAR), "PXASSIGNMENTELAPSEDTIME" NUMBER (18, 0), "PXASSIGNMENTPASTDEADLINE" NUMBER (18, 0), "PXASSIGNMENTPASTGOAL" NUMBER (18, 0), "PXCOVERINSKEY" VARCHAR2 (255 CHAR), "PXEFFORTACTUALDELTA" NUMBER (18, 3), "PXFLOWACTION" VARCHAR2 (32 CHAR), "PXHISTORYFORREFERENCE" VARCHAR2 (255 CHAR), "PXINSNAME" VARCHAR2 (255 CHAR), "PXOBJCLASS" VARCHAR2 (96 CHAR), "PXRESOLUTIONCOSTDELTA" NUMBER (18, 3), "PXTASKELAPSEDTIME" NUMBER (18, 0), "PXTIMECREATED" TIMESTAMP, "PXTIMEFLOWSTARTED" VARCHAR2 (64 CHAR), "PYASSIGNEDTO" VARCHAR2 (128 CHAR), "PYASSIGNEDTOWORKGROUP" VARCHAR2 (64 CHAR), "PYASSIGNMENTCLASS" VARCHAR2 (96 CHAR), "PYFLOWKEY" VARCHAR2 (255 CHAR), "PYFLOWNAME" VARCHAR2 (64 CHAR), "PYFLOWTYPE" VARCHAR2 (64 CHAR), "PYHISTORYTYPE" VARCHAR2 (1 CHAR), "PYLABEL" VARCHAR2 (64 CHAR), "PYMEMO" VARCHAR2 (512 CHAR), "PYMESSAGEKEY" VARCHAR2 (1024 CHAR), "PYPERFORMACTIONTIME" NUMBER (18, 0), "PYPERFORMASSIGNMENTTIME" NUMBER (18, 0), "PYPERFORMTASKTIME" NUMBER (18, 0), "PYPERFORMER" VARCHAR2 (128 CHAR), "PYSUBSTITUTIONVALUES" VARCHAR2 (1024 CHAR), "PYTASKID" VARCHAR2 (64 CHAR), "PYTASKNAME" VARCHAR2 (128 CHAR), "PYWORKCLASS" VARCHAR2 (64 CHAR), "PZINSKEY" VARCHAR2 (255 CHAR) NOT NULL, "PXLATITUDE" NUMBER (19, 9), "PXLONGITUDE" NUMBER (19, 9), "PXCOMMITDATETIME" TIMESTAMP, "PXSAVEDATETIME" TIMESTAMP, "PXCLIENTTIMECREATED" TIMESTAMP Unable to execute DDL statement(s) for work table 'pc_History_MyWorkTable' (History-MyWorkClass): You are not authorized to save instance DATA-ADMIN-DB-TABLE HISTORY-MYWORKCLASS, of class Data-Admin-DB-Table!!! Error while configuring application objects. [ [:You are not authorized to create, modify, or lock instance DATA-ADMIN-DB-TABLE HISTORY-MYWORKCLASS]
I am using PRPC:Administrator Access group to create the application.
Database is Oracle
