Relationship between Revision Management and Operations Manager
Practically, what is the link between Revision Management and Operations Manager 8.5?
Is there a feature that allows the user to access revision management from Ops. Manager?
How can the user access the delegated data tables (not delegated rules)? Is it through Operations Manager or Revision Management?
Context: Client is using Pega CDH and Operations Manager 8.5
@BrianaJ9
Operations manager is an evolution of Revision Management. Revision Management still exists and provides the supporting architecture for Operation Manager. Currently Operations Manager supports a subset of Revision Management capability, with more support added all the time.
Certain Operations Manager users can still access Revision Management through a transition to the CDH portal (or directly within the CDH portal). Operations Manager and Revision Management CRs can co-exist. For more detail on the workflow see this Wiki Page
https://wiki.pega.com/index.php/Business_As_Usual_Process_Flow_in_Operations_Manager_and_CDH
Decision Tables are supported rule types in Revision Management and you can use Revision management to revision decision tables if / when necessary.
