AI4Process
Last activity: 7 Aug 2023 10:35 EDT
Default Database User post Upgrade - PegaAdmin or PegaRules or PegaData
One of my client has recently upgraded Pega version from V7.4 to V8.4. Application Server - Tomcat, Database Server - Oracle.
Our client has used PegaAdmin as default database user to connect to Database during upgrade. Once Upgrade is completed there may three different options for default database user -
- Option#1: PegaAdmin as a default user (mentioned in database configuration file - server.xml) - PegaAdmin schema has required privileges and read and write access on PegaRULES and PegaDATA schema.
- Option#2: PegaRULES as a default user (mentioned in database configuration file - server.xml) - PegaRULES schema has required privileges and read and write access on PegaDATA schema.
- Option#3: PegaDATA as a default user (mentioned in database configuration file - server.xml) - PegaDATA schema has required privileges and read and write access on PegaRULES schema.
For different clients, I have experienced one of the three options. And the options vary from one client to other.
My question is - Is there any Pega recommended BEST PRACTICE for the default database user to connect Pega Database?
Can anyone please confirm?
I have not found anything specific in Upgrade document.
Same question is applicable for any other Application server and Database Server combination.
Note - the upgrade was out of place and split schema.
Thanks in Advance for your response.
