PegaRULES Schema instead of PegaDATA Schema wrongly mapped after Pega 7 Upgrade
After performing upgrade to Pega 7.1 ML 8, we found that work tables, work history tables, data tables etc are wrongly mapped to PegaRULES Schema instead of PegaDATA Schema.
Note that after verifying dataonly upgrade logs we found that ‘ResaveDataAdminRuntime’ step took 0 minutes to process, could you please help us in finding the possible scenarios this issue can occur?
Log:
[java] Computing Runtime Ratios...
[java] ************************************************************************
[java] Runtime Ratio Summary:
[java] Total runtime: 7.47 minutes
[java] Ant Task Breakdown:
[java]
[java] 0.07 minutes, or 0.89% of the total runtime can be attributed to UDFApplicationRuntime
[java] 0.03 minutes, or 0.46% of the total runtime can be attributed to DDLApplicationRuntime
[java] 0.0 minutes, or 0.03% of the total runtime can be attributed to GetSystemNameRuntime
[java] 0.0 minutes, or 0.03% of the total runtime can be attributed to ProcessingConfigurationFilesRuntime
[java] 2.84 minutes, or 38.06% of the total runtime can be attributed to DataUpgradeRuntime
[java] 0.0 minutes, or 0.03% of the total runtime can be attributed to ResaveDataAdminRuntime
[java] 0.0 minutes, or 0.03% of the total runtime can be attributed to ConfigurationRuntime
[java] 4.49 minutes, or 60.12% of the total runtime can be attributed to GenerateUpgradeDDLRuntime
[java] 0.0 minutes, or 0.02% of the total runtime can be attributed to InitializationRuntime
[java] 0.0 minutes, or 0.04% of the total runtime can be attributed to RemoveInvalidSettingsRuntime
[java] 0.02 minutes, or 0.25% of the total runtime can be attributed to CheckingConfigurationFilesRuntime
[java] 0.0 minutes, or 0.02% of the total runtime can be attributed to RevertSystemNameRuntime
[java]
[java] Import Summary:
[java] Total import time (Rules Load, Data Load and System Template Archives): 0.09 minutes
[java]
[java] 0.06 minutes, or 68.77% of the total time can be attributed to load 116 records from Data_All_07.10.01.zip
[java]
[java]
[copy] Copying 1 file to C:\shared\Upgrade\114819_Pega718\scripts\logs
[zip] Building zip: C:\shared\Upgrade\114819_Pega718\scripts\logs\UpgradeDataSchema-CollectedLogs_2015-12-09_04-14-13.zip
[echo] Cleaning up temp directory...
[delete] Deleting directory C:\shared\Upgrade\TempDirs\UpgradeTemp\Temp1\PegaInstallTemp-09-December-2015-04.14.13
[delete] Deleting: C:\shared\Upgrade\114819_Pega718\scripts\resume.properties
