Last activity: 20 May 2020 22:00 EDT
Offline Mobile Date Function Support
Hi all,
I'm trying to get current datetime within the offline mobile application. Requirement is that a certain field in UI should capture current date and time by default and user will have the ability to change it. Is this achievable in offline mobile?
I've tried using @getCurrentTimeStamp() as the "Default Value" for the property in section. But that gives me the timestamp of last full sync - not the current time stamp. Also tried using the function in pre-flowaction DT. But pega fails to run that DT as there is a function call in it.
Appreciate any suggestions on this..
