Stratosphere Technical Consulting
Last activity: 3 Mar 2023 5:13 EST
Offline Mobile - No Sections Loading
When attempting to configure the Pega Sales Automation application for offline use, section rules in the harnesses defined by the mobile navigation rule are not loading. The spinning loading icon appears indefinitely. I have attempted to follow the offline configuration documentation, but cannot seem to get any UI elements to load in a harness. The log off function works properly, and the sync seems to succeed, however.
I have attempted the following to troubleshoot and simplify the configuration:
- Removed section customization to reflect OOTB functionality only
- Reduced the number of OOTB case types enabled for offline use to one
- Use the “My Work” harness recommended in the documentation
- Configure harness rules to use client side template UI, and tried displaying online version of the page (and non-online version)
- Display a harness with only a single button with no actions in an attempt to get any section to load
- Attempted to create a simple case type solely to test offline functionality
This is a simplified version of events, and more detailed steps can be found in the attached document.
Is there some configuration step that I’ve missed here? I would have expected the simple harness/section to load without issue.
***Edited by Moderator Marije to add Support Case Details; ***
