Last activity: 23 Jun 2022 8:42 EDT
Ruleset— No unlocked Rulesets/Versions found that are valid for this record
Getting above error from Pega Personal Edition App Studio. I am a newbie to Pega just started following steps to create the Case but ran into this issue.
Ruleset—
Likes (5)
varnika gupta Stefan Jochems Enrique Gonzalez Mounika Ryakala Rahul Choudhary -
Updated: 14 Jun 2021 7:38 EDT
Could you please switch to Dev studio and go to Application rule by clicking on Definition and from the application stack open the ruleset which got created for your current application and check if any ruleset version is unlocked. If not, please unlock the existing one or create a new one.
MONIKA VUMMADI SETTY Dablu Sharma
I see tons of rules which are locked. Am I suppose to delete those? or go inside one by one and unlock it OR delete the rules?
Also Just tried to save the form without modifying anything but its asking to enter the password. Is it the login admin password or something else. Am stuck at initial phase so frustrating.
PFA
Stefan Jochems
The application rule which you have attached is the PegaRules. Did you create a new application or creating a new case type directly after installing the personal edition?
Creating a new Case Type directly after installing the personal edition.
Could you please create a new application so that application-specific ruleset will be created and you can use this ruleset for case type creation.
Please find the below article which helps you to create the new application.
Anil Kumar Vetcha
What's the password to unlock the Ruleset? Getting below error when on Submit
Enter password that matches the password defined in this RuleSet Version
Which ruleset are you trying to unlock?
seems like you are trying to unlock the OOTB rulesets. I think it wouldn't work.
Generally, we set password for our application rulesets when we lock them.
Chandrakant Shinde
Got it. After creating a new application I am all set. Learned quite a few things in the first lesson.
S MANOJ KUMAR REDDY
Updated: 20 Apr 2021 8:56 EDT
Could you please expalin what you did in detail. I'm still stuck with the same problem like you had.
What did you use while creating the application, cosmos or classic? And whatever you did after that.
MONIKA VUMMADI SETTY Sven Steffen Felgner
JDE
@RahulChoudhary If you go to the rulesets and create/add a new ruleset it is working.
Coforge Limited
@pavan3753 It worked. Thanks!!
