Pega Academy 24.2 DeliveryService “Designing background processing” – Data Pages failing on pyGUID + “No unlocked Rulesets/Version
Hi all — I’m working the Pega Academy challenge “Designing background processing” (Pega Platform 24.2, DeliveryService) and I’m blocked by Data Page parameter behavior and ruleset locking.
https://academy.pega.com/challenge/designing-background-processing/v6
Goal: Job Scheduler queries Business Partners expiring within 15 days (50 at a time) and queues each record to QP Membership-Expiry-Notification to send emails.
Issue 1 (pyGUID parameter blank):
During case actions / processing I see warnings like:
“Required parameter ‘pyGUID’ for data page ‘D_Businesspartner’ cannot be blank.”
Tracer shows the page load is happening without a value being passed forpyGUID. I checked the Data Page rule and my parameter shows Required = No (but runtime still complains / fails).
Issue 2 (generated GUID doesn’t work):
If I generate a GUID (@pxGetNewGUID()) and pass it into D_BusinessPartnerLookup / D_Businesspartner, the load fails because the instance cannot be found — which makes sense because it’s a new GUID and not tied to an existing record.
Issue 3 (ruleset lock error):
I also hit:
I also hit:
“No unlocked Rulesets/Versions found that are valid for this record. Unlock at least one Ruleset/Version…”
even though I have rulesets unlocked. It looks like rule resolution is pointing to a ruleset/version I don’t have open for this rule type.
Questions:
What is the intended source of the Business Partner
pyGUIDin this challenge — should it always come fromD_QueryBusinessPartnerresults and be passed intoD_Businesspartner? -
If I changed the parameter to not required, how do I confirm which version of the Data Page is actually executing (rule resolution / cache) in this Academy environment?
For the “No unlocked rulesets/versions” error, what’s the best way to determine which ruleset/version Pega is trying to save into and which ruleset should be unlocked in the training app?
I can share tracer snippets / rule names if needed. Thanks.
