pyFTSIncrementalIndexer broken
On my brand new pega 8.2 system, i get Search system broken elements.
Any idea how to troubleshoot that ?
Hi, thanks for the awnser and the link that helps understanding how agents work.
I went in admin studio, found the broken elements, clicked on "action" / "resubmit all" and it worked.
Before that i opened the corresponding xml with the error message but didn't understand what to do afterwards so i chose to resubmit.
I'll come back to your post or the article if the problem occurs again.
Best regards
Hi Adrien,
Click on the Broken number count link, it will display the list of all the broken items.
Pick any queue ID item and click the menu (three-dotted) for the respective queue id and click on View XML.XML will show the error information if it exists.
Based on the error message proceed with the next action.
Praveen Vysyaraju
It could be that the Data indexes were corrupted.
You may need to recycle JVM's for all the nodes in the cluster. Make sure you have at least one stream node configured and it is up and running. If this does not fix the issue, we may need execute more steps. You may need to raise a SR for it.
Best regards
Hello Adrien,
You would find the comprehensive document on Troubleshooting Pega Platform Search useful in debugging and fixing similar issues.
Thank you,
Pawan
