Standard Charted
Last activity: 13 Dec 2019 1:22 EST
Date format in Table layout
Hi Surya,
Can you check the source of the table?If the source of the table is report definition and check any column format is applied to the date field.
Standard Charted
Epam
Hi Surya,
Could you please check the property value in clipboard if it is not correct then give a try by providing the control format as pxdatetime on property field.
Gopi
Standard Charted
Hi @Gopinath.A,
In clip board also it is displaying in only MM/DD/YYYY format post changes in presentation tab of that particular property. Also Property type is Datetime with UICotrol pxDatetime value.
Surya Y V
Hi Surya,
Could you please ensure whether the Display value using read-only formatting checkbox is enabled in the Presentation tab of the DateTime (Cell Properties).
Geeda.
Standard Charted
Hi @GeedA
In presentaion tab we are using Edit option as Read-only(always).
For Edit options Auto only we are able to select the option mentioned by you above. PFB image.
Hi Surya,
I have tried with Edit option as Read-only(always) in the presentation tab of DateTime Property and it is working fine at my end. I checked in 8.1.6 environment. Could you please provide your Pega product version? Also, ensure that the Property is of "DateTime" format and the control used in the section is OOTB "DateTime" control.
Standard Charted
