Restrict Case creation on add task when user want to create case second time.
I have a requirement like, we have interaction intent task on click of Add Task the user selecting Test case to create a case now user created a case, now again on same page user click on add task on second time we dont want to show the Test case option again. please help how to handle this scenario.?
please find attachmenet
sadhana
Hi Sadhanag,
We are fetching the results from D_Interaction_driver page and displaying the Intent tasks under AddTask.
If you don't want to display the task once it is launched , you should not add that task to the page and page should get reloaded again.
In "CPMGetIntentTaskByCategory" activity at 10.3 step we are copying the intent task results to D_Interaction_Driver datapage based upon two when condition as shown in the below.
To achieve your requirement, either you can add one more when condition to check whether the service case is present in D_CPMServiceCaseRecents[D_CPMPortalContext.pyID] and you need to reload the datapage D_Interaction_Driver (by referring the page in the activity) so that it will be loaded again and the intent task will be removed from the datapage.
Or
Hi Sadhanag,
Or
You can set the ShowinList property value to false for the corresponding intent task after the intent is launched.We are checking this property value at first when condition of 10.3 step,so if the value is false it won't get copied to the D_Interaction_Driver and after this the page must be reloaded.
