    Nationwide Building Society
Last activity: 9 Apr 2019 13:16 EDT
Openspan Service not working intermittently
Hi Team,
There is one RPA application of ours written in Openspan version 7.1.66, this application targets to launch another application (ex: Test.exe), on click of one button given in UI form.
This application was running fine since 5-6 months, but now we are facing one issue while launching test.exe application on button click. This test.exe is a separate desktop application that internally connects with web service to fetch some data.
We have investigated through logs that while clicking on button to launch test.exe below exception is getting logged:
Exception logged in DB below (using SQL to log exceptions):
->Exception Type: OpenSpan.Common.Memory.SharedMemoryInitializationException
Message : Unable to open private shared memory. Verify that service 'OpenSpan Services' is running
Time Stamp : 03/04/2019 09:27:38
Source : OpenSpan.Common
Method : Void .ctor()
Machine Name:
AUTOMATIONSTEP             EXECUTIONSTATUSCODE   EXECUTIONSTATUSCODEDESCRIPTION
RAEUCAE000004:Starting Test     0              ->Exception Type: OpenSpan.Common.Memory.SharedMemoryInitializationException
Hi Team,
Machine Name:
Time Stamp : 02/04/2019 10:05:44
Machine Name:
As per the message we have seen that Openspan service is getting stopped. Restarting the same also not working as its coming again and again. Can this be related to machine configuration (RAM, CPU Usage etc) as well?
Can you please help that why is it coming to all the systems intermittently even after starting the 'Openspan Services' service manually, or please share any workaround which can be implemented here?
Thanks and Regards
Bhupesh
