Attach pdf to email
I want to a attach pdf to the correspondence and that should be send via email to the user. How can we configure this?
On High level, you can achieve this using
1. Use generate PDF to create pdf file on a temp reference page
2. Call SendEmailWithAllAttachments activity and providing ReferencePage as page where your PDF file is available.
Upendhar V
SendEmailWithAllAttachments will attach all the attachments available on case, but i hope question is to attaching only generated pdf.
Hope this helps you:
https://collaborate.pega.com/idea/way-eliminate-all-attachments-being-sent-using-ootb-corr-rules
