How to attach the pdf to email ?
Hi Guys,
I am attaché the pdf to case. Now i am using OOTB activity to send the email. "
SendEmailWithAttachments". But only message sending pdf not attached for that email .
How to pass the parameter. I using correct way?
Please suggest me.
Thanks in advance!
***Edited by Moderator: Pooja Gadige to add capability tags***
@kirti please check the below link if it helps
https://support.pega.com/question/attach-pdf-file-email
There are ootb activities where you can pass category as parameter and email will be holding those attachments under that category. Please check that also if it helps.
