Running separate BIX extracts - 1 DB and 1 CSV against same data
We have a scenario where two different systems require access to the same data but in different extract formats. We already have a DB insert running and now require that the same data is output but in CSV format (unfortunately we can't generate that CSV from the DB that's the target of our initial extracts.
We will be cloning the existing extracts but changing the output format to CSV. Both will run Stand-Alone. We would like to keep the extracts separate as the DB output already uses our entire window. Any recommendations on how this could be achieved.
